Would a Jotul 118CB Black Bear external heat shield fit an older Jotul 118B
Chinook118
1
Tamworth, NH
I'm interested in knowing if the Jotul 118 CB part # 320099 would fit the 118B, even though it is designed for the Black Bear model. Does anyone have experience with these? Would it do much to dampen the intensity of the radiant heat from the cast iron?
I'm certain the 118B I have is an original as we have documentation and it says Made in Norway on it.
Thank you!
  • Would a Jotul 118CB Black Bear external heat shield fit an older Jotul 118B
Maybe, though it might need some modification. Give Woodman's Parts Plus a call. They may know. In lieu of this, a ventilated wall shield is another solution.
Reactions: Chinook118
What is on that side of the stove? Would a wall shield also work?
