I picked up a SEE (Special Emplacement Excavator) about a year ago in place of something like a Kubota for working around my property and others property. Price wise the going rate for a SEE was pretty close to Kubota with a heck of lot more capability. It also is road legal so no need to trailer it. The Army bought them for the cold war which was ended by the time they went into service so most of the fleet have just sat in depots for 25 years. This one had 40 hours on the engine and 465 miles on the odometer. I did have a few surprises that delayed actively using it, the big one was damage to the electrical harness from a rat gnawing the wiring harness during storage in Texas. Apparently the rats in Texas like Mercedes Benz electrical wires as many of the units being sold out of the Texas depots have the same damage. Its a bit tedious to repair but mostly time consuming. They sell at auctions typically in the 10 to 20 K range, some have been stripped for parts and the auction firms move non running units around with forklifts and sometimes do damage to the suspension. There are also units that were reconditioned by the military that have little or no miles, they go for a bit more.
![Working wood with the Unimog SEE Working wood with the Unimog SEE](https://www.hearth.com/talk/data/attachments/185/185004-3eebdedc8c178b86810f38c0028c5993.jpg)
The backhoe normally resides folded in over the bed when traveling but once its on site the entire unit rotates up into the working position shown. The backhoe is Case 580. It also has a rare for the military optional ripper bucket used for frozen soil and loose ledge. The SEE is quite tall but the wheel base is shorter than a F150. It is very maneuverable. It also has a 16 speeds forward with selectable four wheel drive and air lockers front and rear. The tool boxes on the side held a hydraulic jackhammer, hydraulic rock drill and a hydraulic chainsaw but mine didn't come with the chainsaw.
I drove it about 15 miles over to my brothers place. It has geared hubs to increase ground clearance, that in combination with a short wheelbase and the loader hanging out front makes for slow travel. About 30 MPH is about as brave as I got and on some of the steeper hills in my area it can be real slow trip uphill.
I dug a few trenches around the property ripping out some hardpan and loose ledge and then did some stump removal. It doesn't have the umph to rip stumps outright but using the ripper hooks on the bucket to rake and brake the roots to either side seemed to work.
My brother had a few 2' plus diameter 20' long green white pine logs up on steep slope about 40 degrees. The SEEs have high approach and departure angle so I backed it into a ditch on the side of the road and backed up the slope in low gear, 4wd and locked diffs. From a dead stop I backed up on over about 2' edge of the ditch, no spinning and barely any load on the engine. We chained the log to the pintle and I pulled it down the hill and up the road. The other two logs went the same way. I figure the logs were about 2000 pounds each. The SEE is rated for 5 ton trailer so pulling logs wasn't an issue. There are some videos on the web where folks are using the same base chassis as a skidder in some significant mud and I can see why.
At the end of the day I drove it home after stopping to fill it up. 6.7 gallons of diesel total. This was about 7 hours of run time with about 4 hours of running at high engine speed to support the backhoe.
I am in the process of picking up 30 acres of land that hasn't been cut since WW2 so I expect I will be using it frequently next summer.
