"Back again", and is my face red.....the coal fireplace openings are 22" high by 18" wide, and NOT "'tother-way-round"....
Drove to Buck Woodstoves yesterday at Spruce Pine (NC) and they were very helpful and ethical, and I would recommend them to anyone, but they didn't have a stove which would fit that opening.....does anyone else?
Picture too, that the flue opening is in the "ceiling" of the fireplace opening, and it is the full 18" wide-across, but only 3 and 3/4" forward from the fireplace back wall. The flue is.....in back of that, and I measured 8" from the fireplace back wall to the flue back wall.
In other words....picture a stove with a "box" end 22" high by 18" wide, OR LESS, and a stovepipe fitting, if it is on top, which is
at the very BACK and right up against the stove back wall, and is perhaps oval so that it can take a stovepipe which will fit through a 3 and 3/4" opening, (and then round out into a 4" diameter stovepipe?). The other thing....IF one exists....is a stove with the same back dimensions, or less, and which has a stovepipe fitting on the upper back stove wall.
Also......and keep in mind that I am entirely new to woodstoves.....don't I need some clearance for a stovepipe damper?
....I can't operate a woodstove efficiently without a stovepipe damper, can I?
Can anybody help with the rest?
(...At least...I've learned this much: If the installation is to work, I need an insulated stovepipe from the stove all the way to the top of the chimney....as an 80 year old chimney flue is doubtful at best.)
(Nor do the tiny former Atlantic Maritimes shipboard wood heaters make much sense, as they can barely heat one room.....)
(Also, Anthracite does not make sense in the NC Piedmont, as wood is much more available.......and in any event, can't seem to find either a dealer for coal, nor an anthracite source closer than Pennsylvania....right?)
(and also for now.....I've got forced hot air....and the return duct for the living room where the fireplace is, is about 4 foot from the fireplace....so....couldn't I rig up some kind of heat chamber and fan and ductwork somehow, which would feed at least the entire downstairs heating zone?)
....Anybody have any other ideas for a woodstove or some kind of super-small wood fireplace insert that would fit this fireplace?
