Good Evening,
I've got a Contura 520, with soapstone surround. It's been operational for 9 years and up until mid November it's been completely reliable.
But now I've got a problem, it's smelling of flue gasses coming from the top of the stove, near the front.
There is no visible smoke (I've checked all over many times using a laser for assistance), and so far the source of the leak has been elusive.
I had a chimney sweep come in to try and trace the sourse. He found a gap at the interface between the flue collar and the wood stove. He applied fire cement, being unable to replace the gasket rope (that would require the entire chimney above to be removed in order to remove the flue collar).
After applying fire cement, he smoke bombed the stove, using the door to pump the stove. This yielded no further emissions of smoke. I've since done my own smoke bomb tests a few times.
He didn't charge money for this. He indicated that a proper job would need to be done as the fire cement would eventually crack. However he indicated that it should be enough to keep me going until that time.,
Unfortunately the flue gasses are still coming off the stove and into the room.
Now I've checked all over my stove - I've checked the welds, the back and there are two box tubes that pass diagonally front to back through the stove. I've blocked those off with some aluminium foil, just to try a process of elimination. I've also applied fire grout to any potential candidates for smoke leakage (gaps in the welds, screw tappings etc...
The door seal fails the paper test, but there's no visible evidence of smoke leaking through the door seal. In any case, I 've used clamps to press the door even tighter against the seal, just to rule it out.
My chimney sweep says that there's a negative gauge pressure inside the firebox and chimney, so any leak should pull air in rather than push flue gasses out.
However I applied his logic and checked the flue with a camera - it was completely clear and the chimney sweep already confirmed that it was drawing air in.
So I'm now no longer clutching at straws. I've run out of straws to clutch onto. It's almost as though the smell is being emitted directly from the top steel plating, daft as that sounds.
So does anyone have experience of leaking flue gasses, without there being leaking smoke? How do you trace it?
I would hate to have to condem my stove. It was expensive for one thing, and the source of the failure has not been confirmed.
