I have an existing what I think is called a Martin Industries manufactured fireplace. Two sided. The potential installer said it looked barely used, the stovepipe still shiny inside. Looks the same on the other side.
I want to install a woodstove into the fireplace. The potential installer said that all that is needed is to install a liner within the existing chimney, which is galvanized probably from when the house was built in '93. He said no insulation as the air gap will provide great insulation, and that there is already an air gap so it would be a double air gap. I don't know what this means but took his word and understanding. He's been by far the most professional person that I've dealt with.
Does this sound right to you all? I'm skeptical since it sounds so simple and I have not heard of anyone else doing it. Is it safe and a good solution?
He quoted $2600-$2800 to install the liner and connect the stove (new Woodstock Progress Hybrid) with a rear vent. This seems high to me. The chimney is maybe 36 ft max, so 9 48" rigid liner sections comes to about $1400 but probably a bit less. There will probably be some parts to connect to the stove but should be minimal I assume. How does this sound for a price?
Lastly, are there any concerns regarding heat dissipation from heat from the stove pipe getting caught in the manufactured fireplace? Another installer who came and took a look wanted to create some elaborate heat dissipator with lots of fins as he was concerned. You can see the front is just sheet metal.
Thanks for any thoughts.
