Hello All,
Thank you in advance for any expertise and sharing. I have gained so much from this site over the past decade, I can typically answer any questions by searching. I can't seem to get any conclusive answers on this latest project, I'd appreciate any help/feedback. I have burn't wood throughout my life, boilers, fireplaces and my last house was just a small F3.
This newer house has a pretty big fireplace, 38" wide, 33" tall in the center, slightly smaller width in the rear, and then goes up a 13" square, lined, masonry chimney, about 32' tall (7 yrs old, good condition). This has a chimney top mounted damper, and so much draft that the fireplace actually cools the house in the winter. My wife and a I finally decided to go back to a stove. I have settled on a used VC resolute aclaim, 2490 since if fits nearly perfectly to meet clearences. I plan to heat with this on weekends only, maybe a cord a year.
My questions are with the install, I do plan to buy the short feet so I can actually use the top feed, but I want to keep this set back into the fireplace. I can come right out of the top of the stove and up the chimney... but then what? I have looked at making a block off plate, and then just terminating a stove pipe into it. I know there are concerns with gas expansion, cooling, creasote, etc. So what is the next cheapest option; 6" single wall stainless? Is that really better for the amount I'm going to use this? I could terminate that right below the top damper, or just remove the damper and install a cap. What do you think? This is a larger central chimney with all the appropriate clearences.
I'm also concerned with cleaning the flu/liner. For those that have a similar setup, do you just pull your stove out to clean and then push it back in? I have a 12 pitch metal roof, so I have to clean from below.
Thanks!
![Woodstove in fireplace help, 13" square flu, limited space Woodstove in fireplace help, 13" square flu, limited space](https://www.hearth.com/talk/data/attachments/281/281786-090f20263607ada385e13545a2a84b31.jpg)
Thanks!
