Good day folks i need some help with a woodsplitter i built.The hydraulic oil gets hotter than i would expect.In the summer time when its 25degrees celcius i cant keep my hand on the hydraulic fittings they get that hot.6.5hp,4"x24" ram,2stage pump,10gal resevoir,detent valve.All the lines are 1/2" except for the suction which i believe is 1.25".Any thoughts or experience on this?Also i just installed a pressure guage to see what the relief is set for,with the cylinder extended fully the guage reads around 2300psi which seems correct.A friend told be that the valve or pump could be bypassing causing heat?And my valve should be an open center valve meaning the fluid flows directly through the valve.My valve doesnt apear to be built that way,i cannot see through the inlet or outlet
