Howdy fellow woodcutters,
I'm finally joining the forum instead of lurking in the shadows reading all of your informative writings. I'm looking for a little direction/opinion in heating a big old schoolhouse on which I have closing next week. This house is a 3800 sq ft place with 13 ft ceilings and a lot of windows(thermal glass). and 3800' basement. It has been nicely renovated, seems to be well insulated but I have a strong feeling it's going to take a lot more heat than my current 1000 ft place that I've heated with a small Hearthstone(which I love). Currently heat distribution depends on some radiant in floor heating but mostly it has hot water radiators connected to a big old oil boiler in the basement. The boiler is connected to the buildings 2 story masonry chimney. Now, I have learned a bit in my short life about heating with woodstoves but I don't have much experience with boilers. I'm looking at several options, one would be to convert the old oil boiler to wood, it has a huge burn cavity and I could easily fabricate a grate to hold the wood. I'm not sure if that's smart though since it seems to be a pressure(steam?) boiler and may be on it's last leg. It has heavy rust(no data plate), am I asking for an explosion of some sort? I've also considered installing a wood boiler beside it and keeping the oil burner as backup. I've heard something somewhere about the combination of acid soots eating out the masonry. Is that true?
On to my real questions, the stoves. I might as well start out by saying that I'm limited to what stoves I can find used on Craigslist etc, since my budget doesn't currently allow for a 10k new stove but the two models I'm considering are: an old unused Woodgun E100 and a used Classic CL5648 outdoor boiler. Is the Woodgun super efficient as the manufacturer says, less than the current model E155? Or the same? I'm assuming the Classic is going to use more wood but I kind of like the idea since I could keep the oil boiler as backup with no flue conflicts. Anybody have any efficiency thoughts on the classic. I'm planning to burn pine lumber scraps from a truss plant since this place won't have a wood lot so efficiency isn't quite as big a deal as when you're cutting and splitting logs. You might get the feeling I'm leaning toward the Classic, it's a good bit cheaper and I find at least some aspects of the outdoor part attractive.
Thank you much in advance
