wooden baseboard in a tile-floor bathroom
RustyShackleford
1,367
NC
After enlarging my bathroom, I am also re-tiling the floor. The old baseboard tile ("sanitary cove") is a maroon/burgundy color and it looks just awesome with the proposed new grey floor tile and the newly-painted yellow walls. But since the bathroom is enlarged, there's not enough. I don't mind buying enough new to do the whole thing, but I cannot find the color. I've looked very hard, all over the internet, even ebay.
So I'm thinking of using wood, just like wooden baseboard molding in the rest of the house. I'll paint it with the highest quality marine glossy enamel I can find (suggestions ?), so hopefully it'll look a little like tile and it'll be water-resistant enough. What think people of this idea ?
I have oak on my tile floor in the bathrooms. It's just urethaned a couple times. Looks good to me.
Consider the plastic (pvc)trim. In a wet environment it won't absorb any moisture
Reactions: semipro
We've had MDF trim in our bathroom that I built in 2003. This is on top of a tile floor. It's painted and there have been no problems. After all it's not like there is water sloshing around in there. I used wood for the two short pieces by the shower opening, but the rest is mdf.
could you find a maroon tile that you could cut to the correct width?? I usually use tile for a trim in a bathroom. if you have tile walls the cuts will not show. if you have painted walls you can use a bullnose so the exposed edge is finished. post a pic it might help solve the problem.
Wood will work fine, I just like the tile for continuity.
No, I can't find ANY tile that has a color ANYWHERE close to the color I want (I'll attach a picture).
I like the idea of using PVC a lot; thanks. Water damage will be no issue, plus it's smoother than any wood, so should look even more tile-like after painting.
Never heard of MDF - looks like "medium density fiberboard" - but don't see any advantage it'd have over PVC. Plus, at Lowe's at least, it's only available in plywood-sized sheets.
  • wooden baseboard in a tile-floor bathroom
I did the same with the same results though I put MDF right up to the tub.
Maybe it's a regional thing but about all of the new construction and remodels are using mdf trim. Since the "style" has been painted white trim there is no benefit to using the much more expensive wood. Plus, mdf is awesome to work with. It comes in long lengths, no twisting, or warping, it hides a nail very well, and doesn't split when you nail too close to the edge. It's supposed to be stable so it doesn't shrink/swell with the seasons.
Only trouble is that as a pressed wood product, it should be more moisture sensitive.
Really, even in a bathroom your trim will be more exposed to moisture from mopping than from the bathing activities.
Reactions: fossil
I did that in a previous house. Not worth the trouble over sealed or painted wood, provided it isn't directly in the shower stall. If it is regularly getting hosed down or leaked on enough to cause problems, you will have other problems with the material behind it as well.
Thanks, some good links on tile colors that might fit the bill. Though the Crossville Red/Marron link looks just like an accent, if I'm not missing something.
And MDF looks like the way to go (instead of PVC) if I give up on tile.
I think the Crossville line is pretty complete. Ask a good tile shop in your area. There are a lot of bathrooms where that nice maroon tile is used.
I used a product called Starboard, a marine product in our remodeled bathroom. Totally waterproof.
Thanks for all the links, folks. I've actually managed to find some tile of the right color after all - samples are on the way !
