Wood stove within (not in front of) existing fireplace?
basilseal
14
Chicago
Would very much appreciate anyone's help.
We have an existing masonry fireplace which we'd like to refit with a woodburning stove or insert. There are several inserts that fit the bill, but my wife and I both prefer the look of a freestanding stove.
That said, we'd want the freestanding stove to actually sit inside (or mostly inside) the existing firebox, which is 40" W, 28" H, and 22" D. I found several Jotul stoves that would clear under the 28" height, but they all note that they must be installed in front of the firebox itself -- which we'd prefer to avoid (even if it's more efficient).
My question is: are there any freestanding stoves that can properly be installed within an existing firebox? Or should we just resign ourselves to an insert.
Finally, recommendations for sellers/installers in the Chicago area would be welcome. Thank you!
What Jotul was being considered? 28" is a low lintel to clear. Also, installing a radiant stove in a fireplace can amount to a fair amount of heat loss to outdoors if this is an exterior wall fireplace.
One thing to think about is installing an insert without the surround.
Reactions: basilseal
Thank you, begreen. Both the F445 and F500 have optional short legs that bring the height below 27". It is indeed an exterior wall fireplace.
I had not thought of the other option you propose. I wonder if any are "presentable" without the surround -- would appreciate hearing if anyone's done this!
@EbS-P has this style install and @bigealta has an F400 in the fireplace opening.
I think @Caw has something like that.
I have both F400 in all the way and an insert. The F400 looks better but the insert with no surround heats better. The F400 needs a blower sitting in the floor behind blowing up (both need block off plates).
[Hearth.com] Wood stove within (not in front of) existing fireplace?[Hearth.com] Wood stove within (not in front of) existing fireplace?[Hearth.com] Wood stove within (not in front of) existing fireplace?
Yes, I was looking for pics. Here is Caw's install.
I’ve got a pretty big opening so lots of room for the f400 in the Interior chimney. I use a small fan on the floor to help push the colder floor air under, up and around the stove. Love this set up for my situation. Heats my cape house in NJ.
The 2nd pic shows the air purifier taking the place of the small floor fan.
And yes some of those splits are probably closer than they should be to the stove. They are on constant rotation.
But of course this is not recommended.
[Hearth.com] Wood stove within (not in front of) existing fireplace? [Hearth.com] Wood stove within (not in front of) existing fireplace?
It can be done. I did it with a Pleasant Hearth 2417 with some significant modifications. Being on an exterior wall does rob heat and efficiency. Here are two threads regarding my experiences and modifications:
I got a surround with my insert but removed it in short order. I painted the old fireplace flat black, but you could paint it any color. Or clean up the bricks for the natural look.
Thanks to you all.
After all this, my wife has decided she wants an insert after all!
Listen to the boss.
I have a Blaze King Sirocco insert and after three complete seasons, I really love it. It looks nice, works very well, is neat and tidy, and is a wood miser. The big , wide, window is beautiful.
I didn't believe that a catalytic stove wold be my preference - until I used it for a few months. The "CAT" stoves are fantastic. Little, to no smoke goes out the stack, they squeeze a lot of heat from a little wood, and the chimney liner pipe stays very clean. I could probably put off cleaning for a season or two without any detrimental effects, but it is so easy I do it only once a year in the spring. I do the sweeping myself with an inexpensive flexible brush and a hand drill.
Thanks to you all.
Thank god, nothing worse then taking a radiant stand alone box and shoving it into a masonry hole expecting it to function as is, can it work? sure, but your decreasing the capability of the unit.
Please look up block off plates for your install, and of course, an insulated liner.
And get your wood yesterday.
View attachment 330550 View attachment 330551
luv the jenga stack :)
Reactions: bigealta
Additional Vote for dry wood!
BKVP
