Hi all,
I have been reading and researching for a while but I have been struggling since I started with very little knowledge or experience.
I am buying a 2500 sq ft home in Massachusetts which was built in the 80's. It is currently heated by an oil fired furnace in the basement. There is no option to switch to gas and dislike oil. I plan to remove the oil fired furnace and install a cold temp (hyperheat) heat pump. This will be our primary source of heat but I would like to install a wood stove in the basement using the flue that will be freed up from removing the oil burner. At this point I do not know the status of the flues or chimney but know it is masonry but not sure if it is lined or not, will figure this out asap. There are two main reasons for wanting a wood stove 1) emergency heat 2) to save money/electricity (rates are quite high in MA.) I have access to a lot of free seasoned Ash and Oak to burn.
Other thoughts
1) Trying to decide between used and new. I like saving money by buying used but am concerned about buying a stove without enough experience. Ie looking for cracks or other issues etc. I like that if I buy new I might be able to take advantage of the tax credits and it will most likely be trouble free
2) I like the look of the older style "box" stoves like a Jotul 118 but this look does not seem to be as popular now. I prefer not to have glass buy could deal with it.
3) Planning to buy in the Spring or Summer to maybe get a better deal
4) Over the next couple of years I plan to do a lot of work to air seal and insulate the house so while I want to get a stove that is the right size I would like to go on the smaller side of the right size.
Questions
1) If I buy used what are your suggestions of correct size, reliable, relatively easy to operate efficient stoves
2) If I buy new it is a little easier to find/buy/research but suggestions here? Would want access to tax credits. Tempted by SBI stoves which I think are Drolet and Englander.
I appreciate your thoughts and suggestions
Other thoughts
Questions
