Wood Stove Performance Whats in the Numbers
Huntindog1
1,880
South Central Indiana
I have seen numbers on stoves that doesnt make sense to me.
These are the actual published numbers:
Stove one: 1.4 c/f
Fire box size:
Efficiency: 85%
EPA Emissions: 6.89 g/h
EPA BTU's/hour: 44,000
Stove Two:
Firebox size 2.1 c/f
Efficiency: 76%
EPA Emissions: 3.89 g/h
EPA BTU's/hour: 29,421
Stove 3:
Firebox size 3.3 c/f
Efficiency: 75%
EPA Emissions: 5.7 g/h
EPA BTU's/hour: 30,800
How does a stove operate at a higher efficiency then put out more pollution grams per hour?
Does efficiency actually just relate to how hot your burning the stove and the number is not controlled by the government.
Where as the Emissions number is a Government spec test ran with certain wood and is a controlled test by a certified tester.
It's mostly crap in my opinion. A non cat epa stove is going to burn pretty clean compared to a pre epa stove. You will probably average in real life 65-75 % efficiency and 3-6 grams per hour with good wood and operated properly. Trying to micro analyze the difference can be fun, but in real world use I dont see most people noticing the difference in wood usage between a Quad with a 2.0 CF firebox or a Lopi same size all other things being equal.
I do notice a difference between Cat and Non cat now that I've used a cat stove.
The rest is just eye candy IN MY OPINION!
I agree with Franks.
Also, there is no way Stove One will put out more heat than Stove Two and Three.
I think that if the epa would test real world day to day operation conditions the test results would be much different
cut btu output by a third, in my opinion
One would think that if all the testing was done the same, the numbers would be realitive, but it does not look like it.
I was told by a stove mfg rep that reason the numbers vary so greatly is due to the test procedure. Its a standard test for all sizes of wood stoves using the same wood load (essentially kiln dried 2x4s or something similar).
So I would guess from the stoves you looked at the smalled one shows higher efficiences and BTUs because the test wood load got the stove up to operating temp and it was doing a secendary burn.
As an example. Two stoves in my showroom, same brand. Stove 1 has 1.5 cu ft. fire box and is EPA rated at 43,000 btu. Stove 2 has 3.2 cu ft. box and rated at 44,000 on the hang tag. In real life stove 2 can approach 100,000 btu with proper install and wood.
As for how a stove with higher efficiency gives off more pollution. My best guess would be differences in the baffle between the stoves. Stove one might have a baffle that allow more particulate to enter the flue.
As I was told the EPA test is mostly to determine the emmisions and the btu number is not close to real world use. But I'm sure there are many folks on here that can enlighten us on this issue.
There are 3 different efficiency numbers because there are multiple ways of measuring this. One is the generic efficiency figure assigned to EPA stoves - 75%. Another is combustion efficiency which may be the 76% figure. Yet another is heating efficiency, how well does the stove radiate/convect the combustion heat into the space and not up the flue. That would be the 85% figure. The best advice is to take marketing specs lightly. This goes in particular for the sq ftg area heated.
I'm sure it's a good marketing tool. Is the average consumer going to notice the difference between the amount of fuel they would put in a car rated at 24 mpg vs one rated at 27? Like a stove rated at 75% vs 85%. If that consumer drives 100,000 miles a year, or burns 25 cords of wood, then maybe.
Like a car, it also depends on how you use it. Wide open, foot to the floor, BSEG, gonna suck a lot of gas. Loaded up, air wide open, house at 80, BSEG, gonna burn a lot of wood.
The biggest issue I have with the numbers is square footage rating, burn time and BTU output. Those three numbers, that vary wildly from one manufacturer to another, create a huge amount of problems for new customers.
And the three you mention are three that the EPA is not terribly interested in. The EPA is concerned with air quality, so they don't spend a lot of taxpayer money worrying about, regulating, or measuring anything beyond emissions.
For meaningful measurements in other areas, we'd need to agree that consumer protection agencies should spend taxpayer money setting test standards or that the industry should spend stove buyers' money. I personally doubt that we'll see either.
madison said:
IMHO, firebox volume and stove construction soap/cast/steel, cat/non-cat are what I would look at.
Firebox volume is the best way to go, but even then, there are issues in how the firebox is measured. For instance, the VC Encore has the same claimed firebox size as the Hearthstone Heritage. I can tell you from first hand experience, I can fit more wood in the Encore than the Heritage.
Excellent point BBar
I guess I enjoy the technicality of it all. I am in a technology field by trade for 25 years I have to say I have been programmed by the system.
But you can see there is something not right.
I have to agree with Flagshipsweep, the test is standard but when you put the same size load in a big stove , we all know how hard it is to get a stove up and going when you dont load it fully. Too much open space to build heat. And a Fully loaded stove is going to fire up more quickly as the draw of the flue of a stove with less open area is most likely sucking more air in thru the secondary ports from a stove thats also heating up quicker thus increasing the draw.
Plus i think its said that the cast stoves throw heat better so a figure for how much heat you got from that load actually into the house would be usefull information.
On the surface I would think if the stove has the higher efficiency rating it should have the lowest grams of emission, I just dont understand why thats not so. But maybe if your burning hotter (higher efficiency) your flushing more crap up the flue from the stronger draw created as in faster flue gas velocity.
I'm not so sure about that.
I am confused by these two stoves from the original post:
Stove Two:
Efficiency: 76%
EPA BTU’s/hour: 29,421
Stove 3:
Efficiency: 75%
EPA BTU’s/hour: 30,800
Forget firebox size and look at the other three numbers. efficiency is almost identical, but with very similar output (BTUs per hour) the Emissions are quite a bit different. How would two stoves burning the same wood (I assume they use the same type and moisture content wood for all of these tests) at the same rate (as indicated by BTU output) at the same efficiency produce significantly different amounts of emissions?
I am confused also thats why I posted plus I bet you can list more stoves and be even more confused.
Stove 1: Drolet Eldorado
Stove 2: Vogelzang Performer
Stove 3: Drolet Austral
You can go look the numbers up at their websites.
Here is a Wood Stock Classic:
Firebox size: 2.2c/f
Efficiency: 72%
EPA Emissions: 3.5 g/h
EPA BTU's/Hour: 40,000
Indded, that number too can and is be fudged by some companies' marketing depts. Your example is why Hearth.com members real world reports can be so helpful.
I recall when we started looking at stoves the last time we needed one. The very first place we went we found a stove that was 96% in the efficiency rating. Sales nut smiled wide when he stated that. But he was outdone when we found one that was 100%. Nope, those numbers really don't mean a whole lot and some so-called sales people love to throw around big numbers as they think it makes their product sound great. Somehow, it doesn't do much for the product but surely shows their true colors.
The EPA numbers are the ones report to the Government and tested by an independent lab that are certified to do the testing.
The efficiency numbers are the ones that may be fudged
The more I learn about the test the more I find how really bogus it is. I'll bet no epa stove is anywhere close to as clean in real world use as the numbers suggest. There are tricks used to get a stove through the test and small fire boxes fair better than large ones and shallow fire boxes do better than deep ones and so on. Its a game they play. One of the tricks I heard about is to run the fan on high during the whole test. Few people probably even have the fan option on a given stove and few would run it on high all the time but doing so allows the stove to be run with more air and not over temp. Just knowing its certified is enough. How it got there doesn't matter nor do the numbers.
I hear people talk about having a nice deep stove for a deep bed of ash and coals, my stove is shallow as you cant stack very high plus I have to clean it out after about 3 to 4 full loads of wood. But if I was a bettin man I would say there is some logic in the stove not having alot of head room as just like the fact you have to load the stove up full and high up to the secondaries in the top. This allows a little space up at the top for the secondary burn to happen. The stove will get really hot when you stack it really high and full on a bed of coals. But now just as the stove doesnt do well if its not loaded full to the top as the wood burns down if you have a bunch of head room in the stove the later stages of the burn are farther removed from the air source in the top which we call the secondaries. So I may be wrong but just wondering if thats why some stoves are not large top to bottom as in not having alot of head room.
BTU/Hr output is the most misunderstood and misleading of the specs, and I wish they would either drop it or add more info to make it useful.
Example: Your stove #1 has a 1.4 cu ft firebox and is rated at 44,000 btu/hr.
And the Jotul F602, which has less than .5 cu ft firebox, is rated at 42,000 btu/hr
The key thing to remember is, that number is a peak RATE of heat output. It is not the average rate, but only the peak rate. It is simply the rate of heat production at the hottest point of each burn cycle. It is equivalent to saying "**IF** this rate of heat output could be sustained for one hour, this is how many btu's would be produced."
But it doesn't say for what duration of time the stove can maintain that output rate. The little Jotul would be lucky if it did it for 5 minutes. Stove #1 might do it for 1/2 hour. Maybe.
What would be really great is if they furnished a chart of output rate vs time for an average load. That would be a really useful piece of info to help pick a stove appropriate for your needs.
As others have said, firebox volume is the most useful piece of info. And even that is not spec'ed honestly by all manufacturers.
