Hi All -
I've been lurking on this site for awhile gathering helpful info on an upcoming wood stove purchase. I would like some opinions on the models I've narrowed it down to and some expert advice on my chimney situation.
I have done my homework on the different brands and the models that fit my needs but I am having trouble making the final decision given that these stoves are pretty much equal to me.
Stoves:
Osburn 2300 - comes with blower standard which is a plus and seems to be well made. Main concern is the baffle for the secondary burn seems to be welded in permanently and not replaceable like tubes in most other brands/ models. Price $1299+tax.
* I have looked at the Osburn 2400 also but it is a bit too wide for the space provided to me.
Napoleon 1900 - Seems to be put together well. Concerns are the thin plating on stove and the fire brick being a maintence issue if they crack and come apart. Price $1342+tax.
Quadrafire 4300 millenium - Looks like a great stove, well constructed and efficiencies that can't be matched. Main concern is dealertelling me of issues with the rear baffle cracking in them. He had 2 on pallets with this condition being shipped back.
Price $1360 +tax
Prices are not dead set, this is just what I got them down to with very little debate.
I also have looked at Regency and Avalon. Would like to look at the Lopi but the only dealer near by is very small and does'nt have any in stock and will only order if purchasing. Also price on Lopi is a bit out of my range.
Currently I am using a Garrison stove I bought from my neighbor 6 yrs ago for $100. I'm unsure of the model but it has 2 cast doors and uses a key to lock the door closed and to open. The air adjustment comes from 2 cast discs on the rear of the stove that are on threaded rod to increase or decrease air flow. It also has the original soap stone top. The stove is in my finshed basement and has no trouble heating that area plus most of my upstairs (approx 1800 sf total). We have an open stairway from the basement to the upstairs so there is good draft of heat supplied to the main level. I'm in WI so our winters can be pretty harsh, but seldom does our gas furnace kick in unless temps drop below zero. I really like this stove but I'm sure its efficiency is not what the new stoves are and I would really like a stove that can hold a decent fire overnite, but I'm not expecting miracles.
Now to the chimney. It is 10" insulated dual-wall pipe that is original to our house which was built in 1977 and it runs approx 16'. I clean the chimney myself in fall and then again in winter about midway thru the burning season from the top and bottom. I have never had a problem with drafting with the current stove which has 8" pipe but I'm concerned that there might be a problem going to the 6" pipe on the new stove. The distance of run for 6" pipe from the stove to ceiling where it would meet the 10" pipe is approx 3' if that means anything.
Thank you in advance for any info provided.
Stoves:
Price $1360 +tax
