Wood stove insert
I’m looking to put a wood stove insert in a Heatalator EL36. Any recommendations?
The manual does not allow an insert to be installed in that fireplace.
According to this; 4044_187.pdf (hearthnhome.com) they do allow inserts. Not sure what the limitations would be.
Hmmm you are absolutely correct. The manual I read did not allow them. It must have been revised but there are no instructions for installing one. I think a call to hht is in order
As I understand you can put an insert in, however I have not found one to fit the size of the heatilator.
Call hht. If they allow inserts that is because they tested certain ones which are allowed.
One problem you are going to run into is that there are fewer choices in 2020 than earlier. Normally I would have recommended looking at a small HHT insert by Quadrafire or Heatilator, but those choices are no longer sold. A small Drolet or Osburn may be possible.
