If you're looking for a steamer to put on your wood stove. Lowe's has them for 9.97. That's alot cheaper than the 30.00 I've seen them online for. Now if I could only find a metal can for my ashes that didn't cost 20 bux
Robbie, that is pretty much what we use. Actually ours used to be a sap bucket for making maple syrup. It's kind of beat up but that's okay as it works just fine. After the ashes are cooled we then store them in barrels and then dump them in the garden next spring just before tilling.
How hot should the water in the steamer get? I measured mine at about 150 degrees. I thought this was pretty good but the water level only dropped about an inch over night with the stove running. I thought some people in here were going through alot more than that. It's a two quart steamer and to be effective I would think I should have to fill it up atleast once a day maybe twice.
Well at 150, you ain't going to be making much steam. Isn't your PE a convection stove with a shroud and a cool surface? Might be the trouble. I don't even see steam from my soapstone kettle until the stove top temp passes 500. I do go through water though at the rate of 2 quarts about every three days given my cooler 400 stove top temp.
I bought both the steamer and ash bucket the other day. You need to inspect the items thoroughly, though, because some have objectionable flaws. For example, a few steamers would not sit flat due to the glaze pooling in spots (drips) along the bottom. Also, the some handles weren't firmly attached to the bucket lid in places. These aren't items I would buy sight unseen.
The steemer actually came up as $8.97 when I put in my local zip code, this seems like an excellent price for a nice 2 quart cast iron steemer. As for glaze imperfections on the bottom - I haven't looked at these personally, but if you want maximum heat transfer from your stove to the steemer you should probably grind/sand off the glaze from the bottom anyway.
Go to your local auto repair shop. Some brands of bulk grease come in steel 5-gal. pails.
Also try an autobody shop, as some of the thinners also come in large metal pails.
Cost will probably be $0.
A couple of years ago I attempted to use a 5 gal. metal can that at one time contained shortening used in deep fryers. The lids were hard to get on and off, but the bigger problem was the smoke that came from the painted exterior of the can when I attempted to load it with hot coals. In addition, the can had two handles (one on either side) that made it impossible to carry with one hand. Try carrying a 5 gallon container full of hot coals, smoking like crazy from the exterior paint burning off using both hands and then trying to get the door open so you can get the whole thing outside.
Needless to say that was the last time I used that particular can…
