Hello everyone, I have 0 experience in wood stoves and have a couple of questions about a new wood stove installation. I moved to a split level house, about 2200 sq ft. There is a main level with entrance room, a kitchen and a large living room. There are 2 small rooms in basement with an old wood fireplace. Above basement, there are 3 bedrooms with 2 bathrooms. the basement and the main living room are the coldest rooms in the house. Initially I thought to install a fireplace insert to heat up the basement and the bedrooms. But it seems that it may not work or the room with the insert will be too hot. Another option is to install a freestanding stove in the entrance room, please see the attached plan (hopefully it makes sense). There are 2 air grilles near this location so ideally the hot air from the stove will be distributed to all the rooms. I thought to install a big (3000 sq ft) stove to heat up the whole house but I'm concerned about the room size and if there is enough air to burn the wood. Could you please take a look and share your thoughts? Thank you so much.
![Wood stove for a split level house Wood stove for a split level house](https://www.hearth.com/talk/data/attachments/297/297798-59ac25a2adc8547c328a73f7cf08e58c.jpg)
