A little background. Bought our house on property out in the sticks ust outside of Bristow OK. Prior owners had a real nice large Buck Stove in the living room. The Stove is in great condition but the location was terrible. I took the stove out, demoed the "rock" hearth it was on and built a much nicer hearth about 8' over in the corner of the living room. You can see in the pics the former location and now the new location of stove. Here are my questions.
I obviously need to reconnect my vent/exhaust pipe. Only option is to use the "throught ceiling" in it's current location but run the new vent pipe down out of the ceiling following the slope of the ceiling and then dropping it directly into the flue collar. Prior owner used single wall for this stove inside the living space. Not sure what is used in the through ceiling and up through the exterior chimney above the roof line on the exterior. THere is not attic space to verify anything in the ceiling area.
I live in the sticks so mostly worried about doing it right and not burning down the house. Is single wall stove pipe between the stove and the ceiling acceptable? I will have the stove pipe running about 18"-24" below and parallel to the slope of the ceiling with several ceiling mounted custom brackets. Seems like this should be double walled stove pipe, right? If in fact I should be using double walled will this require me to replace the box in the ceiling to a larger overall diameter to accept, what i think would be a laarger overall diameter stove pipe? Sorry for the beginner questions. Feel free to ask any questions you may have. BTW, it is exceptionally difficult to get anyone who's an expert stove guy out here to look at what i need done and commit to anything. Hopefully this all makes sense. Thanks in advance.
