Sorry for the long post, I am worried I may have had a chimney fire tonight in my wood stove and am hoping for advice on whether it was minor and should be cleaned, or if I should have it inspected for significant damage.
Here was my situation: I have an older wood stove from 1993 that has been in the house since new. The flue is straight up 16’ to a 45 degree angle which then exits through the roof another 5-10’. The stove was cleaned this fall. The outside temp is around -5F which cold temps typically cause pretty strong drafts from this stove, even with the damper closed. Tonight I got home around 8:00pm and the fire in my wood stove had gone out but there were some embers remaining so I opened the damper, threw in some kindling topped with a larger log to restart the fire, and went upstairs to change. Maybe 10-15 minutes later I went down to a roaring fire, a strong metal smell, and I could tell the draft was extremely strong. I closed the damper and the thermostat on top of the fireplace read 600F. I opened the door to let some cooler air in and heard a bunch of rustling inside the flue that I assume was creosote burning/falling that stopped when I closed the door. I went outside and could see sparks exiting the chimney, but wouldn’t say it was extreme, just a few spurts here and there. Once the fire settled down I could still here some rustling inside the flue when the door was opened, but no more sparks from the chimney and eventually everything returned to normal and now there is no noise/rustling in the flue when the door is opened and the hot metal smell is gone.
I am pretty sure I had some kind of chimney fire, but how can I diagnose the severity? I plan to clean the stove tomorrow to see how dirty it is, but anything else I should look for or be worried about?
