I'm in the planning stages for a pole barn, an enclosed wood storage room, a boiler room, gasifer boiler, and 2900 gallons of storage. The boiler room will be 8x8 and the wood storage will be 8x16. My question is if I enclose the wood storage room and place a large fan in the ceiling to vent large amounts of air and I have radiant heat in the concrete floor with 7 cord of wood stacked on wooden pallets, how far will I be able to dry the wood if I burn the boiler in the summer? If I cut the wood in the winter and fill the room in the early spring, how much moisture do you think I can remove from the wood by late October (5 months at 120 degrees and air movement). Can I even heat the air to 120 with radiant or will I need to have a water to air heat exchanger with duct work for the room. I live in a village and the Mrs. doesn't want any wood stack around the building, all of it needs to be stored in the pole barn.
