wood stack height
punchy
Burning Hunk
Jul 28, 2011
164
mid mo
what is the highest you stack splits? i am stacking on pallets and starting a long double row with a space in between. i had a couple t-posts left over from a garden, but they are 8' tall. ends up being about 6.5'. is that too tall for 16" splits? dont want it to lean and tip over.
Highest I go is just shy of 10'. 18" splits on asphalt and they are dry before they go in there.
All of my wood is on pallets and I stack the entire pallet square. I go 6' at the most. Typically between 5 and 6. I don't take out a ladder to stack wood.
4-4.5' is a good height unless you have a reason to go higher, like in a shed or if you just don't have the space. Re-stacking is no fun.
I'll stack until it looks to be leaning one way or another - usually 6-8 feet. Regardless, 1 out of 3 usually continue to lean/fall over within a week. But it is all about space.
+1 except mine are 20" and sit on concrete.
Ja, they need to be dry when stacked or the shrinkage will topple it.
wood stack height
I agree with this, but I unfortunately I fall under the "just don't have the space" so I stack between 5-6 feet.
My outdoor stacks go two rows, about four feet tall on pallets.
Those are stacked green.
wood stack height
4' to 5' is good for pallet stacks & I tie the 2 separated rows together with a long stick in a few places.
Sometimes the rows wobble & I don't want them falling over on anyone, the stick thru both rows helps.
If you have kids that might end up playing on or around them, 4' max.
In my shed, over 6' to 7', jammed to the roof, tie sticks & straps for stability.
  • wood stack height
  • wood stack height
wood stack height
I used pallets like that but use 2 x 4's to secure the standing pallets and raise the height to 6 feet.
the stick to 'tie' the rows is a great idea.
Thanks
Another trick I use is a piece of strap or small rope for the ends.
About every 2-1/2 to 3' of height, lay the strap on top of the row a few feet in from the end, then stack on the strap. Then after after a couple more layers of splits, wrap the strap end up & around the end of the row back into the stack, keep stacking a few layers, then another one if you are going much higher, to hold the ends of the row in better.
Helps stacks make it thru mild earthquakes with out falling over. ;)
Pic may show better than I can explain:
  • wood stack height
After my debacle stacking fresh splits last winter, I am never doing it again at any height. It can hang out in the heap for at least a year. I can heap higher than I can stack and it never falls over.
I'm a pallet stacker too and I go to 4.5-5'. At that height, a 40"x48" pallet is just at a 1/2 cord. Just make sure you get the pallets on level ground - if you plan to have to wood stacked for a couple or more years on the pallets, even a slight lean will start to move the stack, eventually toppling the bugger (unfortunately, I know this well). I leave enough space between pallets that I can just walk through them. Cheers!
  • wood stack height
NH_Wood said:
on level ground
lol, I've heard of that. The only ground I own that is even close I made and some of it has over 15' of fill under it.
I do the same: 5' makes it a 1/2 cord and easy to keep track of the wood supply
wood stack height
Awesome!
Outside in my seasoning stacks: 4 feet high . . . maybe a bit more to make sure I have a true cord.
Inside my woodshed: 6-7 feet high . . . I like as much seasoned wood to be under cover as I can get in there.
On black top i stacked 6'x6'x7' for the first time. I would like to go 8' next year.
  • wood stack height
I stack 7.5' high in the shed (concrete floor), and about 5' high outside (stacked on landscape timbers). I'd go higher in the shed, but the ceiling gets in the way...reason I would like to go higher is because I can reach up to 8.5' without a stool or ladder. Haven't had a stack fall yet (knock on wood).
4 to 4.5 foot high outside max for me. I don't like doing jobs twice and the frost action around here plus wind and can cause topplage pretty easily.
Went higher w/ the holz hausen but that has a much sturdier base.
pen
I stack between trees and or between 6.5' T-posts. Seems like anytime I try to go over 5' tall between trees the tree movement and drying process lets about half fall over. So I keep green wood to about a 4' height. If a few fall over or off its no big deal. it burns just fine with a little dirt on it.
bogydave said:
& I tie the 2 separated rows together with a long stick in a few places...
Ja, if you look real close, you can just make out a long stick leaning against the far pallet that I use. Great minds think alike, eh!
On my woodshed pic, you can make out long sticks at about the 4 foot height. Those don't tie two rows together but they keep the crib ends from blowing out.
my goodness those are some great looking stacks of wood guys, sitting in my office at work and saying dammmmmnnnnn over and over as I look at the awesome stacks
I go between 4.5' and 5' on pallets stacked three rows deep. I have not had a collapse yet and the wood seems to season just fine this way. One year for Ash, Cherry, Locust. The Red oak will have three years this way.
wood stack height
wood stack height
This is one of the short ones. I have a nearly 40' long and 30' long one too.
