After a few years of fussing with tarps, rubber roofing, fence posts, etc, I decided it was time for a shed of my own. The project actually started back in January when I poured through the Show us Your Woodshed thread and scouted out designs I liked. I drew up some plans in Sketchup and went for something relatively simple with good airflow and not too deep. I only wanted to do this once, so I went 36' long x 8' deep, 6' in the back to 8' in the front:
Here is the site I selected... I've got just a little yard and then a bunch of forest, so hard to find enough free space. I built a little model so I could see how it looks from the house. It's hard to tell from the photo, but over the 36' it actually slopes down 3' from the model down to the wood pile between the trees. I considered a tiered design, or building the roof to match the slope of the hill, but instead I decided to excavate and get a level site.
I piled up a bunch of rocks for a retaining wall of sorts and then effectively moved 1.5' of dirt from the high side over to the low side.
Finished site, ready for a wood shed.
At this point site construction was put on hold as we got a bunch of snow that stuck around for a few months.
There are a whole slew of long, straight oak and ash trees down near me from Hurricane Sandy a few years back, even after I cut up god knows how many cords for firewood. I decided to cut at least the major timbers for the project so I bought myself a Haddon Beam Maker attachment for my chainsaw. While waiting for the snow to melt and ground to thaw, I worked on gathering the timbers and posts.
Here is the process for cutting one of the posts... this was a big locust tree I pass every day on my way to/from work. A year or two back the utility company came through and topped it off to keep the lines free. I stopped and left a note asking if I could cut it down and the homeowner said 'have at it.' It was a pretty good size but a strange clover shape.
The Beam Maker is a little jig that rides on a 2x4 or 2x6 keeping the chainsaw relatively straight but allowing it to pivot up and down to cut down through the log. I used a 2x4 screwed to a 2x10 for rigidity, and the whole mess screwed the log. It takes some time to plan out how to cut the log to get the beam(s) you want and then line everything up. That is a 660 with 32" bar for reference.
First cut complete. It is slow going because you are more or less cutting across the end grain. With the longer bar you can angle it a bit, but it's still long, slow work, especially in locust. I would touch up the chain every two cuts or so.
I then rotated the log 90 degrees and cut the next two sides.
Final cut and I have myself a 8"x8"x11' locust post. That sucker was heavy! Cutoffs where cut up into firewood.
There was a big crotch section at the top... I split by hand and that was never going to happen with this chunk, so I sliced it into cookies to maybe use as steppers in a garden pathway or something.
I managed to find enough big locust trees to cut the front four posts all 8"x8"x11'. For the back posts I used locust logs 6-8" in diameter and 9' long.
I followed more or less the same process for the beams. They are 4"x10", 12' long for the middle two and 14' long for the ends. The nice part about beams is you use the 3.5" wide 2x4 and then the jig adds 1/4", so you can just run it down one side, turn it around and run it back the other to end up with a 4" wide beam. Then you trim the edges off which goes pretty quick since you're only cutting through 4" of wood.
Five of the beams are cut from ash and one of the 12' middle beams came from a red oak. Very fortunate to have so many long, straight trees around me, but let me tell you, milling is hard work. It was pretty impressive though how straight a beam you could make with a $80 jig and a 2x4. I just used a regular chain, nice and sharp, and as long as you were smooth in the cut, the finished surface was pretty decent.
Well now it's spring and the ground has finally thawed. I took a break from the wood shed to make some progress on another backyard project... a patio/fire pit. I'm scavenging those rocks from the hill/stream behind my house and stacking them up in that circle. Eventually I'll lay flagstone in the bottom and put a fire pit in the middle. Again the entire back of my property slopes down and away from my house, so inside that circle the near side is a good 1' higher than the far side, so I had to excavate it level.
I made myself a little soil sifter using 4x4 landscape timbers for a frame, some old pallet wood for a carriage and a tray with wire mesh stapled to it. A reciprocating saw shakes the carriage back and forth and the soil falls into the lawn cart below while the rocks tumble off the end into the wheel barrow. I wired a dimmer switch to the end of the extension cord to control the speed of the reciprocating saw. Anyhow why is this in my wood shed build thread? Because while excavating the dirt from the high side of the firepit area, I sifted out the rocks out to use for the floor of the wood shed.
I put in a few weeks work on the fire pit and about this time a couple stacks from 2+ years ago fall over, so it's back to the wood shed project. No pics of me digging holes for the poles, but let me tell you it sucked. This soil is full of awesome rocks for gravel and has excellent drainage, but digging here sucks. My neighbor stopped by and joked that digging around here you get two rocks for every one dirt. It was maybe 25% post hole digger and 50% shale bar and 25% scooping/prying/digging by hand. Awful. Original plan was 3' holes, but new plan is 2' holes. Well a little past 2' and then I stuck a big flat rock in the bottom of each to bring it back up to 2'.
The back posts were small/light enough I could manhandle them into the holes. Pictured at left is my pile-o-gravel from soil sifting.
I'll mention here that at one point I considered doing some timber framing joinery. Read all sorts of stuff, bought myself a big old timber framing chisel, cut a giant cross beam from an ash tree and cut tenons on both ends. Then I spent an ungodly amount of time making one stupid mortise and said forget that, I'll just bolt this thing together. So I used the chainsaw to notch the tops of the posts and eventually fastened the beams using 1/2" carriage bolts.
Sorry for the blurry photo but here is my pal John helping me put the front posts into their holes. These were really too big to move much at all by hand, let alone pick up vertically and carefully maneuver over/into a 2' deep hole it just barely fits into.
Poles are set, level and braced.
![Wood Shed Build Wood Shed Build](/talk/proxy.php?image=https%3A%2F%2Fs3-us-west-2.amazonaws.com%2Fihaveacactusbucket%2Fwoodshed%2FIMG_0310_zps14c9b9wx.jpg&hash=6e13e3a649329e30c45e92beb2e25f08)
