- Oct 3, 2007
- 1,539
My neighbors to the rear and one side have 6' stockade fence surrounding their property, so I get a nice privacy barrier for my yard as well. The neighbors to the other side have a 4' chain link fence. My only option for a privacy barrier is to put up a stockade fence, which would probably cost about $700 for the panels, posts, fasteners, and other miscellaneous stuff I would need. Plus, all I'm left with is a fence, which is not very functional for anything other than privacy. I think I may have come up with another option though. Town code allows for "accessory structures" (sheds, decks, etc...) less than 100 SF to placed 5' off of the property line (fences must be 2' off)-additionally there is no permit required for such structures. Here's my thought:
Along the front half of my property line (5' off) I'll set ten 4 x 4 x 10 posts in the ground 12' apart forming a rectangle 48' long and 2' wide. The posts will be buried Once the posts are set and squared I'll notch them 6" above grade to accept 2 x 6 x 12s. The 2 x 6 x 12s will be supported mid-span by short 4x4 supports that are cut off flush with the top of the 2 x 6s. This way the 2 x 6s are only spanning about 6', which should be plenty for handling the weight. Up top, 2 x 6 x 12s will be run between the ends of the post to serve as bracing, and as something to attach a roof to at some point. Basically this will give me a single row stack 6'-6" high, 2' deep, and 48' long, which is enough for nearly 5 cords of wood. Most importantly, the actual structure will only be 96 SF, exempting me from the permits, and allowing me to take advantage of the 5' setback. It will cost a little less than $400 to construct, so about half as much as the fence and much more useful.
Eventually I'll put some kind of roof on it, and maybe even a back wall so that even when it's empty in march I'll still have a privacy barrier. Also, since I'll still have 5' between the shed and the fence I can store rounds or split wood that needs a few years before "finishing" in the shed. Here's a rough drawing of what two sections would look like (it would have taken too long to draw the rest):
![Wood shed as privacy barrier? Wood shed as privacy barrier?](/talk/proxy.php?image=http%3A%2F%2Fi25.photobucket.com%2Falbums%2Fc68%2FBadfish740%2FWoodStorage_zps17558497.jpg&hash=180060f339c2c5f2b08b99ae3abcae96)
