Can you use it on a deck?
I assume you'd need floor protection just like any stove, but there's no specifics that I could find. They do mention "patios" but I think they'd consider those to be masonry or other non-combustible surfaces.
There is a heat pad listed in the accessories.
Im curious how it works.
With it being gravity fed, what keeps the burnpot from over filling or the hopper from catching fire?
How warm does it get with no blower?
Could this be vented like a traditional stove for use indoors during extended power failures?
There's this line on their About page:
"The gravity feed system is much like a log jam."
So I think it's just that the pellets in the burnpot are in the way and block more from coming down. I also think that's why the hopper is split into 2 10# bins instead of a single 20# one. It limits the amount of force pushing pellets in.
True, there's no blower, but that's normal for a patio heater, they are radiant heat only. The fact that the exhaust is part of the heat output probably provides a certain amount of circulation. It's more akin to getting warm around a campfire than a traditional pellet stove.
So when there's a hopper fire, it burns in stereo(?).![]()
It may sound neat, but it probably doesn't smell too neat. This is one application where clean burning gas makes more sense.Sounds neat. Got a link?
I imagine you starve it for air.Is there a mechanism that stops the flow of pellets into the burnpot if you want to shut it down?
I guess so.From what I've seen so far they are all gravity feed. The two I'm familar with are the Breckwell Monticello (SPG9000) and WayWise pellet stove.I imagine you starve it for air.
But if you cant throttle it down, 65,000 btu. is a lot of heat.Looks great! Simple, be great for those tents designed for wood stoves, with a modification to the vent.
