So my wood situation is not as I would have hoped going in to winter. I've seen a lot of CL ads for free pallets for "firewood." Are we talking campfire wood, or is this really a viable source of wood?
i saw your new stove steup & its lovely. i couldnt see up to the ceiling but am assuming that its bric or rock thru the roof & exposed to the outdoor. if so the stove will heat the hearth's mass & conduct upwrds to the cold exterior of the monolith. rock aint insulative so i see a heat waste conductor. i'd consider foil surrounding the stove & even a fan to push heat out from the hearth. i'd try keep the hearth enclosure cool as possible to avert the heat conduction thru the roofline. pallets burn hot, mix them with wetter or bigger wood~*~Kathleen~*~ said:Thanks for the input. It would be to supplement the seasoned wood I have while the rest seasons. I had not heard about slab wood. There's a sawmill up the road I bit I should check into.
Backwoods Savage said:If you do burn them, remember there are nails in there. So, do you remove the nails before the fire or after? Mostly after but then you have to be careful where you dump the ashes.
The pallets will work as a supplement and can assist if the wood is marginal.
BLIMP said:i'd try keep the hearth enclosure cool as possible to avert the heat conduction thru the roofline.
Hello, what? Why would anyone do that? I do have a neighbor with an excess of seasoned wood. I know him well enough because he helps me with my bees. Maybe I’ll talk to him.Todd said:Maybe you know someone that would be willing to trade some of your wet stuff for dry?
Shipper50 said:Anyone ever tell you, you look like Jillian Michaels from Biggest Loser?
~*~Kathleen~*~ said:Wow Peter!
Still reading and still considering. I may try to get up this weekend to pick some up. I need some more pallets around here for other things anyway, but I am short on time and tools.
I am scrounging and got a truckload of poplar today, but I had one really unsettling experience and I'm a bit more hesitant to follow some possibilities. Stranger danger and all of that.
Here are some photos of a recent kindling operation here. I had this old mini table saw I was given, and I finally got around to trying it out. BTW I would highly recommend an old chop saw (mitre saw) for this sort of work. It would be a lot safer. That being said, this bad boy will churn out a heck of a lot of kindling in short order!Cluttermagnet said:If you have the patience to cut them up, and maybe split the slats, you could think of them as 'kindling'. If you mix pallet wood with regular hardwood in the right proportions, you can get the benefit of the BTU's in that pallet wood, but without overfiring your stove. In fact, if you're 'forced' to burn some hardwood that is not quite seasoned enough (typical for first year wood burners), some really dry pallet wood mixed in would help a lot to get it going and to keep it burning hot enough. Of course with wood less than fully seasoned, you need to frequently check on the chimney/liner for creosote buildup- and have it swept if you are starting to get excessive buildup.
What I do here is to use pallets for a couple of years to stack hardwood splits on- then when the slats start to get weaker and break when stepped on, it's time to saw the thing apart, do some splitting, and stack it all. It makes great kindling. It needs a little time to get fully dry.
A circular saw is great for separating the 'runners' (stringers) from the slats. A Sawzall is 'OK'. For cutting the runners to length, a chop saw is excellent. BTW sometimes older saws appear at yard sales for incredibly low prices. Or are given away by friends on house cleaning binges. ;-)
