A 10 lb piece of wood measures 50% MC. How many lbs will this piece of wood weigh when the MC measures 10% ?
fossil said:Assuming your percentages are by weight, then your 10 lb piece at 50% is 5 lbs of wood and 5 lbs of water. After the moisture has decreased from 50% to 10%, the piece should weigh 5.556 lbs. Rick
WANDERING NAMELESSLEE said:fossil said:Assuming your percentages are by weight, then your 10 lb piece at 50% is 5 lbs of wood and 5 lbs of water. After the moisture has decreased from 50% to 10%, the piece should weigh 5.556 lbs. Rick
Does this mean that .634 gallons of water were removed from the wood? Not being a smart azz. Trully curious how this works out.
jdinspector said:...So, perhaps the question is more appropriate to ask -A 10 lb piece of wood measures 40% MC. How many lbs will this piece of wood weigh when the MC measures 10% ?
I can't figure that one out.
fossil said:
fossil said:In humans it's anywhere from ~55% to ~ 70% or so. Rick
LLigetfa said:This may fall into the "too much information" category but I drank an awful lot of water today doing a bowel prep for day surgery tomorrow, so I think my MC might exceed 70%.
fossil said:How can anything be more than 100% something?
