We have an existing fireplace and want to put in an efficient wood-burning insert. Local (Washington state) code requires 16" of hearth in front of the fireplace opening, and that's exactly what the builder put in (using stone). The fireplace is flush with the floor (see photos). The flooring in front of the stone hearth is 3/8" ceramic tile on 1/2" gypsum board (all on plywood). The gold fireplace doors shown are 44" wide x 33" high.
Reading through various stove insert manuals, it appears that, by the time I put in the insert, I will exceed the required hearth distance in the front of the stove. For example, one requires "16 inches in front of the fan housing", another (flush mount) requires 17-7/16" in front of the insert's door. T he black tile area in front of the stone hearth is a traffic area, so I can't build up there.
Is there an existing insert that might work in this situation, or is there a low-cost solution anyone can think of?
![Wood Insert & Hearth Size Problem Wood Insert & Hearth Size Problem](https://www.hearth.com/talk/data/attachments/191/191888-2888ee4828ea0c835fadf0a0cfdf2de3.jpg)
