Does anybody know the efficiency rate for a good wood burning insert?they say my pellet stove is 81%.
Thank you john
Thank you john
burntime said:Remember with wood you can scrounge it too...pellets stoves make you a captive audience. .
BeGreen said:In general you can use the emissions certification as a rough guide. A cleaner burning stove should be more efficient, but I don't think the numbers are directly related. For example, the Quad 3100i is certified at 1.26gm/hr and is rated at 78% efficient. But the 4100i is rated at 3.1 gm/hr and they say is 76% efficient.
But then there is how well the stove recovers heat and returns it to the room instead of up the chimney. Can someone tell how that is tested? Corie?
Combustion WorksheetBut then there is how well the stove recovers heat and returns it to the room instead of up the chimney. Can someone tell how that is tested? Corie?
HaaaaaaaaaaaaBS :exclaim:Mike Wilson said:I have heard that a PE insert is about 126% efficient, 131% if you get the one in Whorehouse Red...![]()
-- Mike
TMonter said:But then there is how well the stove recovers heat and returns it to the room instead of up the chimney. Can someone tell how that is tested? Corie?
Second page outlines how efficiency is calculated.
Basically it calculates the heating value of the wood and the moisture content of the wood being burned, looks at stack temperature and calculates efficiency based on those values.
burntime said:Regency was 77 percent and the door is less arched. Good luck. Also I think the mansfield was more boxed shaped if I remember right.
Is that a direct indicator of how good a radiator or convector the stove is?
karl said:You're right Mike. I have to pull a few pieces of wood out of mine every morning. If we have a cold winter, I don't know where I'm going to stack the stuff. It's really piling up.
