Wood Insert Choices
Shamrock132
1
MA
Hello,
We're looking to convert our fireplace to a wood insert. After talking to a couple shops and looking online, the choices seem endless! Looking to get any opinions or advice on the ones we've seen so far. We live in eastern MA. Our house is 2 stories, about 1300 sq ft, built in the 50's with an external chimney. 2 shops gave quotes on Regency, Vermont Castings, Napoleon and Hearthstone. Ideally we would use it a few times a week, more as a supplement then a primary heat source.
The first 2 quotes were for a Regency Alterra and Vermont Castings Montpelier. This shop recommended non cat stoves, saying that unless we were planning on really keeping the fire going for days at a time, it wasn't worth the savings and maintenance. They said that larger stoves might be too hot for our space. They mentioned the Regency has an adjustable air control while the Montpelier doesn't. They quoted about $6800-7000 installed for both, with the Montpelier being a little more. Both would be ordered with a delivery sometime in December.
The second shop gave quotes for stoves they had in stock. A Napoleon Oakdale EPI3, and a Hearthstone Clydesdale. The Napoleon is on clearance as it's discontinued. I'm slightly familiar with Hearthstone as we have some family with a Heritage stove that's about 25 years old, they love the soapstone and how it has a gradual heat. These stoves were estimated around 7300-8000. They mentioned that the Clydesdale is one of the few inserts that qualifies for the tax rebate.
Would love to hear any thoughts or any stoves that we should consider. Thank you!
Are you looking for a catalyst insert or non-catalyst insert, very important as the catalyst burners require more maintenance, the Hearstone as an example has 2 catalyst to maintain and eventually replace, one each side. As you will probably live with your chosen insert for many many years to come it is an important consideration.
The Regency Alterra is a good looking flush insert. It's a little small but should be ok for supplemental and ambience fires. Also consider the Osburn Matrix 1900 in this size range. The Napoleon Oakdale EPI3 is larger and was a good basic heater. It will have longer burntime and can push out more heat if needed. The Vermont Castings Montpelier is a single-burn rate stove. You fill it and light it and let it manage the fire. This is not the best for 24/7 heating, but ok for ambience fires. The Pacific Energy Vista or Neo 1.6 insert is a good choice in this size. The Clydesdale is a hybrid cat stove. So far the reviews are mixed for performance. In hybrids, the Lopi Medium Flush is a more reliable performer.
