Wood Duck said:I think that is mulberry. The alternate, heart-shaped, toothed leaves are typical of the leaves on the tips of branches of some mulberry trees. Most White Mulberry (the common type in PA) have also some mitten-shaped leaves, and two-thumbed mitten-shaped leaves, but most have simple leaves like these as well. The bark looks like mulberry, and so does the yellowish wood. Although the leaves look reasonably good for elm, and so does the bark, the yellow wood seems more like mulberry. The leaves are definitely not locust or hickory - these are simple leaves, not compound.
bsearcey said:It is not walnut or hickory or locust if the leaves shown come from the same tree. All three of those have pinnately compound leaves.
(broken link removed to http://www.dof.virginia.gov/trees/walnut-black.htm)
(broken link removed to http://www.dof.virginia.gov/trees/hickory-pignut.htm)
(broken link removed to http://www.dof.virginia.gov/trees/locust-black.htm)
Hackberry does have a serrated leaf like that, but the bark is all wrong and the heartwood can be dark in hackberry, but not like this piece.
(broken link removed to http://www.dof.virginia.gov/trees/hackberry.htm)
Mulberry doesn't have a leaf like that and the bark is off.
(broken link removed to http://www.dof.virginia.gov/trees/mulberry-red.htm)
The leaf IMO is classic Elm with the one side of the base of the leaf margins being a little lower than the other side and the serrated edges. From the description on the DOF website the bark sounds right for both the slippery elm and the american elm. Check the underside of the leaf. Slippery elm should feel fuzzy.
(broken link removed to http://www.dof.virginia.gov/trees/elm-amer.htm)
(broken link removed to http://www.dof.virginia.gov/trees/elm-slippery.htm)
The only thing that doesn't fit for me is the way the PO said it split. Could just be lucky and got an elm with a straight grain.
