No its not Black Cherry. looks like locust. Cherry does not spark, its excellent burning and very clean. It dries good. You can go weeks without cleaning out your stove. Burns down to almost nothing.
If its locust..which is what it looks like I believe that does spark.
Does locust have a very sweet smell and lighter than comparable oak split?
"Cherry or Black Cherry also burn at medium heat level, though do not burn quite as well as the other hardwoods.
Trust me I would want it to be locust over cherry all day!! Another thing I forgot to mention is the dust from the bark is a very fine red powder that gunks up everything when mixed with the bar oilLocust has a distinct smell, but I wouldn't call it sweet. A green split of locust is a bit lighter than a similar-size green piece of oak, because oak has a higher initial moisture content, but once it's dry, their weights will be very similar.
Anyhow, what you've got there definitely isn't cherry.
I still think it's sassafras. Which, like cherry, is only middling in the heat department but smells good. Take a look at the pics here.
The locust ID just doesn't fit. The bark is wrong for honeylocust, and the color is wrong for black locust.
That would be the outer most rings correct?particularly in the rings of earlywood
This is one of those times when looking at the end grain with a magnifier can help a lot.
Here's sassafras at 10X. Note that many of the pores, particularly in the rings of earlywood, are completely open and clean.
