Ok I have a PE Summit and I love it. It heats the house entirely if I work at it but I still wake up to cold mornings sometimes. I'm going to be traveling even more this year than before, so the furnace is going to be used to keep the house around 55 degrees while I'm gone.
My current natual gas furnace is 44 years old. Hey it's rated at 80% efficient. Maybe back then but surely not now. Anyway I had a furnace given to me. It's in good shape and not terribly old. My old furnace was 240,000 btu input and 180,000 btu output. The new one is 100,000 input and 80,000 output. That's quite a downsize, but I think I'll be ok. The Summit is rated at 97,000 max and 46,000 over an 8 hour burn and like I said it did well. Besides in the 60's they really oversized furnaces. I will also be insulated the duct work as well and probably adding insulation to the house.
The new furnace will be vented out through the side of crawl space instead of up through the roof like the old one. The furnace is in the basement. This leaves me with a huge whole from the basement to the roof. I know it would need a proper liner but still it's there and I could use it for a wood add on furnace.
What are some of the furnaces out there? I've seen a few in the 1000 dollar range. Are there EPA requirements on these? Which ones have secondary tubes? Etc
I probably won't buy one this year. I still have another year and half or so to recoup the cost of the Summit. I woud like to have a wood furnace that I could light when I get home along with the Summit to heat this big house up from 55 to 70 quickly.
Thanks for your replies,
Karl
Karl
