I just had a Englander wood burning furnace installed in my basement and I have a question on the amount of air being pushed into my duct work.
I see the blower on the furnace has around 850 cfm but can I help it with running my fan in my heat pump? The install has the 8 inch discharge in the very far end of the trunk of my duct work and the heat pump and fan are at the other end of the main ducting.
I have found if I run my fan only from my heat pump I get another 2-3 degrees in heat on a thermometer I use for reading the temps in my house. I just don't want to over run the duct if that is possible. I have duct board ducting if that is what it is called.
I wish I would have put in this furnace before I spent $3800 on a new Regency I3100 installed that is undersized for my house, I went from keeping the temps in my house at 63-65 to 72-74 after installing the furnace and I don't have to run my heat pump which is a electricity eater.
Thanks for any help,
Shipper
Shipper
