I am building a new house and installed a 2-sided wood-burning zero-clearance fireplace. The builder used to gas fireplaces and had power and a gas line run to the unit as well. The unit has outside combustion air, glass doors, exterior venting. The gas line has already been run through the knock out hole in the side.
Is it possible to use the gas line for an igniter for the wood fire? It seems dangerous to have a gas line in a wood fire. I may just have it removed and the firebrick replaced.
Any ideas? I can't find anything online except one article that mentions "if you have a gas igniter in your wood burning fireplace". If this is possible, surely there must be some do's and don'ts.
Thanks,
A
Thanks,
A
