Hi ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
My wood burning fireplace is in need of work. There is nothing wrong with the prefab firebox, nor the chimney. The sidewalls are too close to the firebox (min. clearance not met), the hearth is too small, and there is no caulking. The last part is easy - I think.
Here is a pic of what it looked like before I pulled off the sidewalls. The manual calls for 21.5" sidewall clearance (for combustible material), and as you can see, the walls - which are painted wood - are literally adjacent to the firebox.
![Wood Fireplace - I am going to ask you fine peeps for some assistance Wood Fireplace - I am going to ask you fine peeps for some assistance](https://www.hearth.com/talk/data/attachments/294/294371-7cf1a000472f2db67cc9f0697fb441de.jpg)
The original idea was to take off the sidewalls, and move them outward to spec, having no idea what I was going to do with the space in between, and not knowing what was going to be behind those side walls. After thinking on it, I decided to simply ditch the sidewalls and go up with stone. So, I take off the sidewalls, and the trim, and I see nothing but drywall.
![Wood Fireplace - I am going to ask you fine peeps for some assistance Wood Fireplace - I am going to ask you fine peeps for some assistance](https://www.hearth.com/talk/data/attachments/294/294372-ec212394d06aaf2d096357a2e9f37bbe.jpg)
My first thought was to just leave it, and install the stone onto the drywall, but then I am thinking, 1) even with the stone, the drywall is maybe not supposed to be that close to the fbox (sides and top), and 2) can you really install stone directly onto drywall? Prolly not.
I then took off some drywall that was next to the fbox:
![Wood Fireplace - I am going to ask you fine peeps for some assistance Wood Fireplace - I am going to ask you fine peeps for some assistance](https://www.hearth.com/talk/data/attachments/294/294373-d0b8ee117595057cec40e256ad1b1c34.jpg)
On the l side there are three studs. Not sure about the r side yet (prolly the same). The first stud has an attachment to the top of the fbox, the middle stud has an attachment to the bottom of the fbox (not sure why the box is att to two diff studs), and I assume the third stud (not really visible in the pic) is a framing stud. But not sure just yet.
What I am thinking now, is I have to rip off enough of the drywall, to 1) not have any too close to the fbox, and 2) expose some studs, so that I have something to screw backerboard into. Then mortar and then stone. Does this sound like a plan, or is there a better way to approach this?
Also, do I replace the hearth before I do the b.board and stone, or after, or does it not matter?
Thank you!
Thank you!
