I searched for "kiln" in the forums, and didn't see any topics related to pottery kilns, so here it goes...
I've been interested for awhile now in designing a pottery kiln that's run on alternative fuels (ie: not LP, natural gas, or electric). I thought that this forum would be a good place to pick some brains.
I'm quite familiar with traditional wood fired pottery kilns. They usually are made with "hard brick" (dense hard clay) as opposed to insulating fire brick (IFB) which is almost like pumice in its weight and texture. This is because the superheated ash from the wood burn (the kiln must reach an internal temperature of 2350 F) contains a "flux" of sodium and/or potassium which "sticks" to the walls of the kiln and melts and erodes the bricks inside as well as the shelves that the pottery are stacked on. Hard brick is cheaper, as the kiln must be rebuilt less often and with less expense.
I'm curious about some of these wood fired boilers that heat the wood to form a gas, before sending the gas into the combustion (pottery?) chamber for a super efficient fire that reaches over 2000 F. The problem with a pottery kiln (the reason I'm posting here) is that I get the feeling that in a traditional pottery kiln, the combustion reaction is much less efficient than the modern boilers out there. The inside of the kiln is a super dense thermal mass that must be heated (the quicker the better...) to an ultra hot temperature. To get the kiln (and the pottery) to this temp, wood must be hand fed into the kiln every few minutes, constantly, for 24-48 hours. I get the feeling that this constant process of opening the stoking door(s) lets unnecessary air into the combustion chamber, resulting in an inefficient fire. (not to mention that whenever a new (cold) piece of wood (usually 4"x4" or so) is added, black smoke comes out the chimney as the combustion reaction loses heat and is overwhelmed by excess fuel for a few seconds...)
My idea is to combine the ultra refined and engineered wood burning boiler with the fringe "artsy fartsy" millenia-old kiln technologies of ancient Japan, Korea and China. (Google "anagama" or "noborigama" kilns of ancient China)
Where should I go to find schematics of the wood combustion reaction, blueprints of current wood burning boilers, and details details details. I want to know what material lines the combustion chambers of these newfangled boilers, and do they eventually get lined with ash deposits (shiny glass-like deposits on the brick). Would it perhaps be possible to convert a boiler's burner mechanism to feed the fire directly into a larger combustion chamber such as a kiln?
		 ITC100 will also reflect heat- some well respected potters ascribe magic powers to the stuff's ability to even out heat and reduce firing times when coating IFB's.
