I live in Southwester Ontario in a reasonably well insulated 2500 ft2 home. I've been heating with wood for quite a while using a Pacific Energy wood stove, and am considering installing a wood gasification boiler in my garage. I'm hoping the boiler will have several advantages over my wood stove, one being the frequency that I need to feed the fire. I know that feed frequency will depend on different factors, including my plan to install 800-1000 gal of storage. For those here that have an EKO or Tarm boiler with storage, I'd appreciate any information on how often you find you need to feed the unit. My preference during the main heating season would be to rarely need to restart the fire. In the ideal case, I could simply scrape around the remaining coals and then re-feed the boiler without needing to use any kindling to help the fire get going. This is my current practice with my wood stove, and I can keep the stove going for weeks without needing to restart the fire or use any kindling. With a Tarm or EKO coupled with heat storage which would cause a relatively high burn rate, would I realistically be able to feed the fire say 3 times/24 hours (morning/noon/evening) and not need to do anything other than scrape around the coals and throw more wood on? After a 12 hour period, would there be enough coals left to restart the fire?
I also have a basic question about heat storage using open versus closed loop. Is the main reason for using a tank with a heat exchanger versus simply circulating the water in the tank to reduce the potential for corrosion in the boiler? I assume closed loop systems are used because it is easier to control the quality of the water in a smaller, closed loop system.
Thanks for your help.
Stuart
Stuart
