Hi all,
Has anyone tried to build a wood dryer using their boiler as the heat source? I run my boiler in the summer for dhw and was thinking that would be a great time to shorten some of my wood dry time and since I was already using the boiler I could build a cabinet that would have about 48 cu. ft. of space (4' x2' x6') and dry the best part of a face cord using an old (or new) heater core from a car as the heat exchanger. I would just tap into the return line on the boiler and route through the heater core and back into the boiler from there. It would be a plywood/2x4 design vented at the bottom and top for gravity air flow and have simple cabinet hinges for the doors. The dryer would put a little extra load on the boiler so I would be getting a little less idling during the burn. The reason I ask is I am having trouble getting any real seasoned wood (I've been given an opportunity to cut green wood but don't have enough dry set up for next season) and know I am going to run into problems this coming winter. Any pro's/cons?
