Wood burning stoves
Itslay90
439
Upstate,NY
why were pre epa wood burning stove bigger inside the firebox vs the new epa wood burning stove seems like it got smaller inside
Efficiency. It's much harder to keep the firebox at the temps needed for proper combustion with big fireboxes. Which is why the only big ones now all have cats. Where firebox temps don't matter as much
Lower efficiency. Wives saying 'not in my living room'?
There are still several 3.0 and larger cu ft stoves that don't have cats. (Drolet, Osburn, SBI, Quadrafire, Lopi Liberty, etc.)
Yeah but that seems to be the limit without a cat. And that is considerably smaller than the big old boxes pre epa
Fewer 8” chimneys too. If companies thought they’d sell, they’d probably make the bigger stoves.
Well that is absolutely all about efficiency although tge majority of older stoves had bricks as well. Many even added baffles as time went on
They add durability as well. Shielding the walls, ceiling and floor from direct fire will keep the stove around longer. It’s easier to replace a baffle than the top of the stove. Similarly, bricks are cheap.
