Hi, recent lurker and first time poster. Looking for advice on wood burning stove location and selection. Sorry in advance for the long post.
Background:
![wood burning stove selection wood burning stove selection](https://www.hearth.com/talk/data/attachments/299/299220-beda3551e62106b45043c071794cc6a2.jpg)
Background:
- Interested in a wood burning stove for two main reasons:
- Add an additional way to heat our house, which is currently heated using natural gas
- We have an abundance of wood to burn
- House: unusual "rambling" style, with three sections. Picture below
- A high-peaked octagonal section
- with a central fireplace with stone facing on all sides. The fireplace is a prefab unit. Because we recently learned that prefab fireplaces won't last forever, and it would be a major project to replace (given the stonework), we don't use the fireplace much
- 1 story section
- this sits between the high-peaked section and 2 story sections
- 2 story section
- Stove location: we are thinking of installing the stove in the main room of the 1 story section
- ~725 sq ft room with a vaulted ceiling
- Kitchen, informal dining , family room. Open layout.
- Has an existing gas fireplace that we never use. The gas fireplace has wide cabinets on both sides, and is bumped out into the main room.
- When discussing possible stove locations with a nearby dealer, they thought ripping out the gas fireplace and cabinets would be our best option.
- We are thinking Vermont Castings, because that is the main line offered by our nearby dealer, and we like the idea of top-loading
- Given the unusual roofline, is the proposed stove location viable from a flue performance perspective? It is somewhat in-between the high-peaked octagonal section and the 2 story section
- What Vermont Castings stove would work in the proposed room? We want to burn longer pieces of wood, but are sensitive to overpowering the room with the heat of the stove
- Possibly related to the above, would a stove with a catalyst be something we should consider? Not sure if a catalyst gives a stove a wider range of clean burning temperatures, and we might be able to operate the stove at a somewhat lower temperature vs without a catalyst.
