Hi, I have a wood burning stove fitted into our lounge which continues to emit a harsh chemical smell which I don't believe is smoke. The stove was installed a year ago. It's an Evergreen double doored stove, 7kw. The smell is present even when I burn lots of paper, or dry logs, so it doesn't seem related to bad fuel. The stove is fitted into a recess which is painted with black emulsion paint. The register plate is steel with a trapdoor. The flue pipe is fitted into a steel liner. I recently had a HETAS engineer round who checked the liner and fitting (cctv) and said the liner had no cracks and was fitted correctly. We have an electronic CO2 detector and that is zero. It's driving me nuts and means we can't use the stove as the fumes are too potent.
Any ideas? I am thinking of taking the whole thing apart including register plate, flue pipe and connector and putting it all back again. I just want to get this sorted as winter will be here soon.
