We are looking for a large (3 cu.ft. firebox or larger) wood burning insert for our fireplace. For reference, this is our existing fireplace (the fireplace opening seems small, due to the metal cover on the fireplace):
Most other dimensions and clearances for the fireplace seem OK. However, the wooden surround below the mantle seems to throw things haywire. Its combustible surface. The measurements for top of the fireplace opening to the combustible surround (right below the mantle) seem to be below the minimum most manufacturers/codes want.
The one insert I have been able to narrow down that fits the bill (I think) is the Lopi hybrid-frye. The details of the clearances are listed in the document below and they seem to all fit fine:
http://www.lopistoves.com/TravisDocs/100-01273.pdf
However, I don't like the "flush" look that much, and I am unsure if flush inserts is a good idea given that we want the stove primarily for heating (and secondarily for aesthetics!).
I imagine at least a few folks around here have had the same problem. What other inserts would you recommend for our setup? I would hate it if the alternative is to remove the wood surround or to have an ugly heat shield sticking our from top of the stove. I really hope that there are some other stoves out there that will work in this case, and that I am not left to the one Lopi hybrid choice which I am not too crazy about.
More details about our fireplace:
Fireplace dimensions:
19.5" Depth
35" Width opening, narrows to 19" Wide at the back wall.
26" Height
clearances:
Hearth depth: 24"
Mantle column 8.5"
Mantle (from bottom of the fireplace up to the wood surround right below mantle): 44"
From top of fireplace opening up to the wood surround right below mantle: 17"
![Wood burning insert with low mantle/surround Wood burning insert with low mantle/surround](/talk/proxy.php?image=http%3A%2F%2Fi96.photobucket.com%2Falbums%2Fl189%2FTheOscarGuy%2FDSC_0445_zpstm7yvitl.jpg&hash=e6489da41edf8d0a051b6481d8a7300c)
19.5" Depth
26" Height
clearances:
Hearth depth: 24"
Mantle column 8.5"
