Hello everyone,
I have been browsing this forum for a few months and have found it to be the single best resource in my search for a high-efficiency wood burning insert. With my 1st post, I hope to pick your collective brains a bit.
We have a large Cape Cod - 2,000 sq ft on the main floor and another 1,000 sq ft upstairs (including the airspace of a cathedral ceiling). I have attached a couple of pictures of the main living room which also shows the current ZC fireplace which is centrally located in the house.
![Wood-Burning Insert Advice Wood-Burning Insert Advice](https://www.hearth.com/talk/data/attachments/129/129213-6ca37d3762e886ffc4cd5d3a22fa8621.jpg)
Our power bills were horrible this winter and I have 50 acres of woods...burning wood for supplemental heat seems quite logical.
The ZC is a Heat-n-Glo model which is strictly ornamental (picture attached). It generates little heat and likely costs us money to use as it sucks more warm air up the flue than it radiates. The chimney is lined with 30' of CF11 - standard chimney for these types of fireplaces - 11" ID / 13" OD. The Chimney is about 35' off the ground, on a 12/12 roof and about 4' above the peak of the roof (attached a pic for that too). It is not easy to get up there so I am wanting an insert that allows flue cleaning from the bottom up. I plan to do this cleanings myself (and have an annual sweep inspection).
![Wood-Burning Insert Advice Wood-Burning Insert Advice](https://www.hearth.com/talk/data/attachments/129/129214-771032e259efce49b27ff1330cceabce.jpg)
![Wood-Burning Insert Advice Wood-Burning Insert Advice](https://www.hearth.com/talk/data/attachments/129/129215-f9957334e7672c220005a3725956719b.jpg)
The ZC fireplace seems fairly large...39" W x 24" H x 19" D. During my research, it appears that only a few inserts designed for use in ZCs wouldn't fit...and those were due to the 19" depth.
The boss is wanting a flush insert for aesthetic reasons - a free standing stove is not a viable option. She could perhaps be persuaded to consider an insert that extends onto the hearth maybe up to 6"...but flush is her clear preference. I have a Generac home backup generator (LP) and the fans for the insert would connect to a generator circuit in case of a power failure.
We are quite rural and there is not a bevy of dealers in our area (Shenandoah Valley in VA). One dealer handles Quadrafire and PE. The other dealer handles Jotul, Lopi and others (but only Jotul is on-site). They aren't keen on the idea of putting an insert into a ZC fireplace. But there are local chimney companies that will pick up the insert and install it along with the 6" HT liner that I am hoping will slide nicely inside the existing 11" ID chimney.
We have been seriously considering a Grand Voyager (even though I have not read gushing reviews on this site). The Boss liked the looks (as it was flush), the unit would handsomely cover the opening with cast surround and, while it probably wouldn't heat 3,000 sq ft, it would help cut down on electricity and LP bills (heat pumps).
While browsing the Quad installation manual, I noted that there is a "t-bar" which attaches the flue to the insert which effectively bisects the flue opening coming up from the insert. According to the Quad rep that my dealer spoke with, this "t-bar" makes it "next to impossible" to clean the chimney from the bottom up (unless you remove the insert each time).
So, we may be back at square one...and seeking your advice.
We think that we are looking for:
![Oops! :oops: :oops:](/talk/styles/default/xenforo/smileys/ohh.gif)
John
![Wood-Burning Insert Advice Wood-Burning Insert Advice](https://www.hearth.com/talk/data/attachments/129/129212-47d0f6ef3ecc7385c1ae1e6b2067f429.jpg)
- The largest insert that will fit in my ZC
- From a reputable manufacturer of quality fireplaces
- That is either flush or "almost flush" and
- Can be cleaned from the bottom up and
- Will pump as much heat as possible into a 3,000 sq ft area.
John
