Can you effectively stack two heat exchangers on the same flue pipe to double your heat output? I configured my wood burning stove this way but I'm having problems with the top heat exchanger staying on consistently.
Nope one is a bad idea 2 is a horrible ideaCan you effectively stack two heat exchangers on the same flue pipe to double your heat output? I configured my wood burning stove this way but I'm having problems with the top heat exchanger staying on consistently.View attachment 325103
I've been using the Magic Heat exchanger for the past 10 years and it works very consistently well by warming up about 2/3rds of my 1500 sq ft. house, raising the temperature by about 10 degrees within a little over an hour. I was hoping for the same effect in my back bedroom with the Miracle Heat exchanger.Nope one is a bad idea 2 is a horrible idea
Overloaded electrical socket...Also the CO producing ash bucket nicely in the home...
The safety gate is to enhance obliviousness in kids, so they never take responsibility for themselves, ignore good advice, and to always believe big brother will take care of them.Is this a troll post or is it for real?
Puts a safety gate around the wood stove but kindling stored right nest to stove.....
I bet bholler's blood is boiling![]()
Yes, I have stiff nylon brushes I use to clean the single wall Duravent pipe each year before the cold weather sets in, and I burn hard wood only, I try to stay away from burning pine.You need to check your chimney for creosote. The heat exchangers cool the exhaust gas below the condensation Temperature
Nothing wrong with pine at all. What moisture content is your wood at? How much crap do you get in your chimney?Yes, I have stiff nylon brushes I use to clean the single wall Duravent pipe each year before the cold weather sets in, and I burn hard wood only, I try to stay away from burning pine.
Ditto the pine.Nothing wrong with pine at all. What moisture content is your wood at? How much crap do you get in your chimney?
No, I don't let the creosote build up, when I'm done brushing out my flue, it's very clean. I'll remove the heat exchangers and clean them separately.Looks like a chimney fire waiting to happen to me.
For two very small fans and one 5 watt light bulb, I'm not concerned at all about overloading my circuit.Overloaded electrical socket...
It brushes off very easily when I run my brushes through the pipe.A year at desert climate could be fine, depending on sun and wind exposure.
I don't like seeing flaky stuff as it means it was liquidlike when deposited. You want powdery stuff.
What about your chimney? You are either running the stove wrong and dumping massive ammouts of heat out the chimney or you are going to have creosote issuesIt brushes off very easily when I run my brushes through the pipe.
Is there a problem with cold ashes in an ash can with a tight lid? I have a screen that filters out the ashes so if there's any hot coals, I'll separate them and use them for the next fire.Also the CO producing ash bucket nicely in the home...
I don’t have a chimney, just a wood burning stove with a flue pipe.What about your chimney?
