wood burner id
Iatrapper
86
Iowa
Anyone ever seen or herd of this one? I think the metal tag on it says little jhony, it's hard to make out. Hopefully I got the picture to come up.
  • wood burner id
Never heard of it, but looks like it's installed too close to combustibles.
Are you looking to buy this stove to install in your home? Shop? Is this currently at your residence? What are you looking to do with the unit?
I put it in my garage last fall, the picture does make it look to close but it's not, 18 inches on the side and 18 inches from the stove pipe. I was just wondering if anyone new anything about it.
Looks like it was shop built, not a production model.
An untested and certified stove requires 36" clearance to combustibles from the sides and from the back of the stove. The 18" rule is for floor protection, not walls. The 36" clearance can be reduced with a proper form of NFPA211 wall protection. I would screw some cement board or sheet metal on 1" spacers to protect the stud in back of and to the side of the stove. Leave a 1" ventilation gap at the bottom of each wall shield.
yes what begreen said but that will still only cut clearance by a third so it would be 24". 18" to the pipe is right atleast
Reactions: Owen1508
i stand corrected that's what i get for trusting my memory.
U guys r full of good info, I'll b putting up some cement board spaced away from the wall and moving the stove out farther. All I've ever Ben told is 18 inches Is good.
Reactions: pen
With that proper wall shield, right where it sits at 18 inches away should be just fine.
How's the old girl work as a heater for the garage? Looks like one heck of a setup with the blower on it!
I know the feeling, trusting memory at my age gets on thin ice.
I can get it up to 70 when it's in the upper teens outside, takes a while with no ceiling and no insulation. Hope to get the garage insulated this year. Only one blower works but it's more than enough. I've got it disconnected from the chimney right now, going to sand it down and hit it with the high temp paint. Pretty happy with it.
looks like it should do fine for a shop heater. What type of chimney does it run into?
