Have a oak tree 150 gal wood boiler been working on for sometime now. I ran about 80ft of 1 pex to the house which is down hill from the stove then back up the hill so total of 160ft. the supply coming in the house goes up about 4ft to my water to water plate exchanger then goes back down 4 ft and over about 20 ft to my furnace with a 15x15 heat exchanger then back the 20ft to the return for the boiler. The pump that came with the boiler is a taco 07 pump. I hooked everything up and purged air out of the lines many of times just making sure there wasn’t anymore air pockets. The pump is circulating water but maybe not fast enough . My stove is set 175 and it barley cuts on . I’m not pulling any warm air through my air exchanger the line coming in on it is hot and the one going out is much cooler but my 10plate water exchanger is working great.
![Wood boiler not exchanging heat Wood boiler not exchanging heat](https://www.hearth.com/talk/data/attachments/274/274039-1b787e309c88da56c5fb68f6e4e35f0e.jpg)
![Wood boiler not exchanging heat Wood boiler not exchanging heat](https://www.hearth.com/talk/data/attachments/274/274038-870065f8b6e67f87fe507b8e1be7b285.jpg)
