Hi!
New member here![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I have owned many wood stoves, love the idea of turning my large wood supply into usable heat instead of shoving it on big piles and burning it out in the open.
At the same time I got tired of tracking dirt, dust, smoke, scorpions, ants and the whole works into the house. So I've been looking into the wood boilers with a hydronic heat system.
I was primarily looking at these brands:
1. Glenwood - currently at the top of the list because their multi fuel boilers (7030M) can automatically switch over to a waste motor oil burner. The downside is that the multifuel boilers are not gasification systems.
2. Alternative heating systems / woodgun. They also have a model WOC40 that can use waste oil as a backup however it seems less sophisticated, manual switch over instead of automatic. They also have a gasification system including one that's stainless steel that's supposedly more resistant against corrosion from the gases in case you use wood that's too wet or run it too cold and get buildup.
3. Portage and main - they don't have any oil backup option but their burners seem to be well liked, so if I decide not to use a backup heat option then PM seems like a good reliable choice.
Does anyone have experience with the Glenwood boilers?
I have not found much information about them except one guy on youtube who goes on and on for hours about everything he dislikes about them. But they've been in business for a long time so I have a hard time believing that they would be THAT bad..
I'm also trying to decide between the gasification systems which seem cleaner and more efficient, but also finicky, vs a traditional (multi fuel) burner which will take anything that burns and is very flexible at the expense of being more efficient. I don't mind to keep my wood under a roof for the summer months , but a lot of them say it also needs to be split and whatnot. I want a boiler that's big enough so that I don't need to be splitting wood.
Thanks!
Rodney
New member here
Thanks!
Rodney
