Wiring the NO Zone Valve into the Aquastat on the oil boiler. Question?
NewBoiler
45
Canada
I need to wire my mormally open zone valve into the triple aquastat on the oil boiler (per diagram attached). This allows the oil boiler aquastat to turn on the primary circulator when the normally open zone valve, opens. However, as you can see in the diagram it must connect to T1 and T2 on that aquastat. However, the L8124L aquastat I have on my oil boiler does not have a T1 or T2 connection. It does however have a T and TV connection as seen in the 2nd attached document. Are these the connections I need?
  • Wiring the NO Zone Valve into the Aquastat on the oil boiler.  Question?
