Hello All!
I have ordered an Osburn 2400 insert and it should be here in a week or so but I have some questions if anyone can help!
1. I have read about inserts having a "heat sensor" in the fan so that it will come on once the stove is preheated and turn off once it cools down. I have tried to find info regarding the Osburn but cannot find the answer. Does this model have this type of blower?
2. I did see that the fan has low and high speeds. My old insert (80's era Buck) had a rheostat on the fan which allowed for infinite fan speed adjustment. I am handy electrically so could I take out the high/low switch and install a rheostat?
3. The insert is going into masonry fireplace with a "Heatilator" type blower system that used to blow air from the fireplace to a vent on the other side of the living room and one in the hallway. The blowers were controlled by a thermostat in the hallway which is pictured below. I am toying with the idea of running the outlet that the insert blower will plug into off of this thermostat which will turn the fan on and off based on the temperature down the hall toward the bedrooms. Any thoughts?
Thanks and I am sure I will have many more questions in the very near future!!
