WIRE BRUSH ON S/S FELX PIPE?
budman
620
Valley Cottage,NY
Just wanted to fined out if i can use a wire bursh on s/s felx pipe or am i doing harm to the pipe.THANKS
cozy heat for my feet said:
There are a couple of threads out there that cover this in depth. The general consensus is to stick with poly brushes for SS.
Corey
THANKS COREY
Make sure the chimney is cool before you poke that poly brush into it.
I seem to recall something about how you can use a wire brush if it's one inch in diameter smaller than the pipe, but I think it's best to stick with poly in any event. Over time I think the steel brush will scratch the surface of the SS, shortening its life.
THANKS ERIC
