Have we had a thread about this already? How about a quick chekclist of tips from the experts on how to maintain your chainsaw before putting her away for the winter. (Assuming you do put her away for the winter)
Gibbonboy said:All of my equipment gas, mix and straight, gets stabilizer added as soon as I buy it. That keeps the octane up plus keeps it from varnishing. My stuff starts right up no problem, and if I don't use my snowblower much, for example, I know it's ok to sit. Doesn't add that much to the price of the gas, and it stays fresh, especially in the summer heat when gas can lose a good percentage of its octane rating.
Corie said:Eric, what is this book you two kooks are speaking of?![]()
Eric Johnson said:I don't do much. The most important thing is to run it out of gas or drain it, so that you don't try to start the next season with stale fuel.
If it makes you feel better, you can clean all the sawdust and oil out. This might be a good time to change the fuel and/or oil filters, clean the air filter and clean out the bar groove and oil ports.
Store it in a clean, warm, dry place.
Corie said:Hey hey hey. I'm not only a coal burner.
Didn't you see the thread on the stove I built? That was a wood firing making those secondary jets dance baby!
babalu87 said:Corie said:Hey hey hey. I'm not only a coal burner.
Ooops my bad, order up the book and some wedges then
Sta-bil (there are other name brands out there as well) works great.
As far as chain saw gas, do you opt for the 93 octane or just go with the 87??
I need to find me a ripping chain, I have some pieces of Oak that cant be split.
downeast said:Why "winterize" your saw, that's for our boats.![]()
Winter is when we do most our woodlot work except for extreme snowfall. Best time to cut next winters' firewood and commercial wood. It's cooler. No bugs !! Easier to move you and heavy gear in otherwise wet or mucky woodlands. Skidding on frozen or snowy ground is smoother and slick. Less damage to soft ground. Need more ?
Don't you get all heated up cutting ? :red:
We put our saws to bed for the hot month(s): July.
